1998 Chevy Camaro cylinder compression
1998 CHEVROLET CAMARO
43,000 MILES • V8 • 2WD • MANUAL
ARNIEB
i am in the process of doing a compression check and i would like to know what the stock compression should read in pounds per cylinder ? ihave checked to cyl. so far --150# and 185#. i thank youvery much. arnie b.
Mar 7, 2009 at 2:50 AM
MMPRINCE4000
  • 8,548 POSTS
Check all cylinders, the highest and lowest should be no more than 20% difference, if more than 20% then possible headgasket/intake gasket problem.
Mar 11, 2009 at 1:53 AM
