1997 Chevy Camaro will not accelerate; has no power when gi
114,500 MILES • 6 CYL • 2WD • AUTOMATIC
SEITZ12
My camaro has a rough idle and accelerates with a great amount of hesitation. I have checked spark plugs, replaced fuel filter, and ran injector cleaner through the fuel system, but I cannot find the cause of the embarrassing accelerations. Any suggestions will be apprieciated.
Mar 17, 2010 at 12:59 PM
  • 75,988 POSTS
Lack of acceleration,chugging,hesitating,bogging etc. could be caused by one of the following below.
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Mar 17, 2010 at 2:06 PM
