1997 Chevy Camaro water in oil but no oil in coolant
DIZ12U
  • 5 POSTS
Engine Mechanical problem
1997 Chevy Camaro 6 cyl Automatic 125000 miles
when I pulled the drain plug on oil pan, a stream of clear (like drinking water clear) water came out for about 10 -15 seconds. Never seen anything like that before. Then when that quit the milky looking oil came out. When i loosened the oil filter to remove it, clear water came out from it also, just a small bit though.Car has been sitting since sept. 2007, because it died going out of driveway, I thought it was out of gas, put a gallon in, still no start. So I assumed it must be fuel pump. now i dont know, since i find water in the oil. help please. what to do, and how to test it
Apr 28, 2008 at 10:46 AM
  • 75,988 POSTS
Get it block and pressure tested to confirm a blown headgasket, cracked head or block-
Apr 28, 2008 at 10:57 AM
