1997 Chevy Camaro OIL GUAGE
1997 CHEVROLET CAMARO
97,500 MILES • V8 • 2WD • AUTOMATIC
DRIFTER769
MY guage hand all of a sudden starts at 80 lbs. on the off position, than after i turn key on buries itself all the way over. even after i start it.doesn't move when running,when i shut engine off it drops to the 80.... I replaced the sending unit,,didn't change a thing,, What is my solution for this problem??? Thank You
Oct 13, 2008 at 5:12 AM
RHALL77
  • 3,361 POSTS
soounds like you have a problem in the cluster. you may need to replace the IP cluster
Oct 13, 2008 at 5:29 AM
