Engine Mechanical problem
1997 Chevy Camaro 6 cyl Two Wheel Drive Automatic
I have a 97 camaro that will miss realy bad and wont stay running. Once you get it started and run the rpm's to about 2000, it will stop missing and run fine for a while. There is no codes in the pcm. Can any one tell me whats going on. Is it the converter stopping up, or fuel pump. or any thing else you can think of that would cause it.
Feb 26, 2009 at 4:45 AM
