1997 Chevy Camaro gas milage and performance
1997 CHEVROLET CAMARO
65,000 MILES • 6 CYL • 2WD • AUTOMATIC
CEOPCC65
  • 6 POSTS
any ideas what P0305, P0441 and P1406 would have in common?
I ve replaced Plugs, Wires, Ignition coils, ICM Module, EGR, O2 sensor and Cat Converter. Checked Vacuum lines, no leaks seen.
The Plugs for cycl #5 appear good, except a small brownish burn mark at tip. When I changed plugs again, I used ithrium and after 100 miles, again very small brown discoloration on the 1 plug. I do not feel any real hesitation or misfire when driving.
The P0441 comes and goes. The P1406 has never left after replacing EGR 3x.
The gas milegae drop from 300 miles a tank to 200 miles a tank has been the most noticable.
Thanks
Jul 30, 2010 at 8:34 PM
HMAC300
  • 48,601 POSTS
you probably have an ijector problem as well as an egr that may be stick or clogged with carbon and a cannister purge valve that is bad or the gas cap is bad....... you 'll need to fix it to get your fuel mileage back and a scanner to erase the codes.
Aug 2, 2010 at 6:24 PM
