When i apply the breaks, the right break light goes compleatly off! even the running lights. when i let off, the running light comes back on.
Feb 4, 2009 at 11:52 AM
BOWTIE BABY
MEMBER
Chances are its just a bad ground or a crossed wire. Check the bulbs and the wiring. Tighten all the groung wires, there should be a ground stud with a few wires and a nut. If neccesary remove all the ground wires and clean them and reinstall.
