1997 Chevy Camaro Brake Lights not working
BRUMBYGAL
Brakes problem
1997 Chevy Camaro 6 cyl Two Wheel Drive Automatic
The brake lights work ok on normal running lights, however when the brake pedal is depressed the brake lights go out with the exception of the 3rd brake light.
All other running lights are working, including backup and turn signals.
We have checked the bulbs and they all seem to be ok and are new.
Mar 4, 2009 at 10:17 AM
EUGENE123
  • 273 POSTS
check the fuse that goes to your brake lights and if its bad replace it
Mar 17, 2009 at 5:55 AM
