1997 Chevy Camaro Brake lights
95,000 MILES • 6 CYL • 2WD • AUTOMATIC
KSKEGLER
97 Camaro Left brake light stays bright, but with lights on and you press brakes right side tail lights goes out. Center brake works
Apr 26, 2010 at 6:44 AM
HMAC300
  • 48,601 POSTS
your ground to the tailights has gone bad. If you fix that then the lights should work ok on both sides.... it will be a black wire
Apr 27, 2010 at 1:40 PM
