Over the past several months, I've noticed that the lower the fuel level gets, the less of a turn I have to make before the engine does this, eventually making even a 90 degree right hand turn challenging, as you have to plan on waiting 3-4 seconds after stopping the turn for the power to return.
At first, I thought I was simply running out of fuel, but an immediate fill-up took only 8 gallons (15 gallon tank). Then I replaced the fuel filter. No change. Spark plugs, wires, coils. Same problem.
Three mechanics I've talked to are baffled, and aside from the items I've already repaired, they have no remedies.
Any thoughts?
SPONSORED LINKS
Friday, May 7th, 2010 AT 8:10 AM
