1996 Chevy Camaro..Grinding noise in throttle body
TIFFANY_DOUG1228
Noises problem
1996 Chevy Camaro 6 cyl Two Wheel Drive Automatic 150k miles
I have a 96 camaro v-6, 3.8. It is very slow to start but fires up ok after it runs for a while but makes a really bad sound when it does start. At first i thought it was the water pump bearings going out ( the sound it very similar ) but the pump is new & after more inspection the sound appears to be coming from the throttle body area. The sound goes away after running the car for about 5 min ( unless you hit the gas). I also put my hand over the intake ( just barley ) & it dies immediately. There is a slight knock in the motor as well & i don't think the people i bought it from maintained it well at all good thing it was cheap. Can anyone help please?
May 23, 2010 at 11:29 AM
HMAC300
  • 48,601 POSTS
have a pro in your area look at this. things like this are very hard to diagnose on the computer and really need to be looked at and heard to give a proper diagnosis.
May 24, 2010 at 10:46 AM
