1996 Chevy Camaro Windshield Wipers CAMARO Z28
100,000 MILES • V8 • 2WD • AUTOMATIC
MYRENTHEMIGHTY
I have a '96 Camaro and the windshield wipers do not make full contact with the windshield. I have made sure the arm is tight on the motor and there are new blades on the whippers. When the whippers are on they miss/do not clear the center of the windshield. How can I fix this? (And yes everything else is in working order, and the arms are not bent)
Sep 4, 2009 at 6:30 AM
  • 110,248 POSTS
It sounds like the wiper arms are bad. Not the blade, but the arm that it attaches to. There is a spring that pulls the blade to the window. If the get old and rusty, they lose their strength and do what you have described.
Sep 7, 2009 at 3:38 PM
MYRENTHEMIGHTY
Thank you. I had though that might be the problem. I will let you know when I get them changed out.
Sep 8, 2009 at 1:13 AM
  • 110,248 POSTS
Let me know if you have other questions. Also, check out a salvage yard.
Sep 8, 2009 at 1:26 AM
