1996 Chevy Camaro Tank pressure sensor
1996 CHEVROLET CAMARO
157,000 MILES • V8 • 2WD • AUTOMATIC
DUSTNZCAR
I have a 96 Z28 camaro that the "service engine soon" light just came on. The code says that the Tank pressure switch is not purging, or senses the pressure wrong in the gas tank. anyway I thought it was bad so I replaced it. The code cleared but i drove the car about 400 miles and it codes again. I was wondering if maybee the gas cap isn't sealing, or i have another sensor that went bad. If not what could be causing this code?
Jan 12, 2009 at 11:07 AM
BILLYMAC
  • 2,204 POSTS
hi dustin..billlymac here. yes your cap could possibly be not sealing. a cracked vac hose or even a seal on the top of the tank but normally it will be just the cap.hope this helps feed back is appriciated.billymac
Jan 13, 2009 at 11:07 AM
