1996 Chevy Camaro Rear shocks or springs
14,500 MILES • 6 CYL • 2WD • AUTOMATIC
CAMARO_RS_96
I have a 1996 Chevy Camaro RS. I have a problem with the car bottoming out. I have replaced the shocks already and working on replacing the coil springs now. By replacing the coil springs, will that fix the problem I am having?
Nov 7, 2010 at 8:49 AM
DRCRANKNWRENCH
  • 3,380 POSTS
Replacing the springs will generally fix that type of issue. However, I would look into a few otherr things as coil springs wearing out on a car is somewhat rare at that mileage and age.
First, shocks do not have anything to do with ride height or carrying any of the load of your car. Some vehicles will get or have a coilover strut which is different as the coil spring does seat on the shock.
But in your case the coil spring and the shock are 2 seperate things. Shocks only control the motion of the spring and prevent, "the Pogo" effect.
Since you are having issues and have shocks already, check them because bottoming out a new shock will blow the seal out and ruin the shock.
So, when you bottom out, are you carrying a large load or on a bad road?
Has the suspension been modified?
Are the rims and tires the stock size?
Also, bushings can wear out, but seldom cause a bottom out.
Let me know how it goes.
Nov 7, 2010 at 9:05 AM
DENTONO
i have the same problem on a firebird 96 as well its your bumpstops its a common problem with them
Jun 17, 2012 at 12:59 PM
DRCRANKNWRENCH
  • 3,380 POSTS
If the bump stops are getting hit it is still bottoming out too far. The springs need replacement. A quick fix to get you by is a coil spring spacer. You can try to find one online and there is a site called, www.carrepairlinks.com that has a bunch of the best online retailers and custom shops that have hard to find parts. It is a good palce to start and if you order through links on site you get special discounts.
Jun 23, 2012 at 1:11 PM
