1996 Chevy Camaro P1351
150,000 MILES • V8 • 2WD • AUTOMATIC
WILLL
  • 5 POSTS
i have a 1996 Camaro 5.7 LT1. i have the trouble code p1351 Ignition control circuit high voltage. I have replaced the ICM, Distributor, Alternator and Opti spark wiring harness. I have replaced everything short of the entire wiring harness from the VCM. Any suggestions?
Nov 8, 2010 at 12:16 PM
DOCFIXIT
  • 18,828 POSTS
Measure voltage from ICM terminal "B" and ground is it between 1-4V?
https://images.2carpros.com/forum/automotive_pictures/198357_Graphic_705.jpg
Nov 9, 2010 at 6:51 AM
WILLL
  • 5 POSTS
hey can u send me the direct link to that schismatic so i can enlarge it and save it for future reference.
Nov 9, 2010 at 7:23 AM
DOCFIXIT
  • 18,828 POSTS
Nope but you can go to Repair Manuals on this site and get entire manual from Mitchell on Demand @ $10
Nov 10, 2010 at 1:46 AM
WILLL
  • 5 POSTS
I got a weird reading of -0.12 on the meter disclosed in photo
https://images.2carpros.com/forum/automotive_pictures/590619_111010121356_1.jpg
https://images.2carpros.com/forum/automotive_pictures/590619_111010121222_1.jpg
https://images.2carpros.com/forum/automotive_pictures/590619_111010121337_1.jpg
if i am at a wrong setting or on the wrong connectors please let me know. Key is in On position.
Nov 10, 2010 at 6:38 AM
DOCFIXIT
  • 18,828 POSTS
Meter needs to be on 20 scale DCV
Nov 10, 2010 at 6:42 AM
WILLL
  • 5 POSTS
https://images.2carpros.com/forum/automotive_pictures/590619_111010132914_1.jpg
and this number jumped around from -.35 to -.29
Nov 10, 2010 at 9:12 AM
DOCFIXIT
  • 18,828 POSTS
Check from B to engine bolck if voltage then ground C black mis faulty
Nov 11, 2010 at 3:41 AM
WILLL
  • 5 POSTS
@ Docfixit I sent my car to a shop to test the electrical for me and they told me that i needed to reprogram my PCM or something was wrong with my pcm and i needed to take it directly to Chevy for service.
Do you have any friends in California i can take this car to personally? This Vehicle is not a regular Camaro. I got this car from a retired Lt. from the highway patrol in Oregon and this car has many Chevy Add-on's i do not trust with just anybody.
I took the car to Pontiac/Chevy dealer when I threw my timing chain and they told me i threw a piston and i had a hole in my piston. I took the car home and fixed the timing chain myself. Same motor is in it now. You can see why i Try not to take my car to shops because i just get screwed for money i do not have.
She runs so great. I replaced ignition control module, distributor, opti wiring harness, coil, crank sensor, alternator, everything with ignition short of the PCM and the entire motor harness from the PCM.
Nov 15, 2010 at 9:18 PM
