1996 Chevy Camaro engine starting problem
150,000 MILES • 6 CYL • 2WD • MANUAL
SCOTTIE1
I have a 96 rs with a 3.8 . it was running fine and my cousin drove it. he ran it up a dirt embankment ,not very big, then I tried to start it. it cranks over, has 45psi fuel pressure and spark is good. I replaced lock and key ,switch, from dealer thinking it was anti -theft problem. it will start and then dies imedaitely. every thing checks good. no security light . I looked the car over good and can't find a thing unpluged or wrong. fuel pump runs and I have checked all I can . no codes , the check gages light stays on although the gages read fine. it's like it gets gas for a monute then shuts down. it has to be electrical, what can it be and what should I check?
Jun 5, 2010 at 1:39 PM
  • 75,988 POSTS
When the ignition switch is ON (Engine off) and the fuel pump is running, the fuel pressure indicated by the fuel pressure gage should be 333-376 kPa (48-55 psi). Yours is on the low side
Aug 17, 2019 at 9:56 AM
SCOTTIE1
[quote:d8ada48585="rasmataz"]When the ignition switch is ON (Engine off) and the fuel pump is running, the fuel pressure indicated by the fuel pressure gage should be 333-376 kPa (48-55 psi). Yours is on the low side[/quote:d8ada48585]
