1996 Chevy Camaro check service light
193,000 MILES • 6 CYL • 2WD • AUTOMATIC
PAUL0465
I have a 96 camaro. the service engion light and oil lights are on. I need them off to smog it. I changed all the oil and tranny fluid so i dont know why the oil light and engine lights wont turn off. if you could give me some suggestiions that would be a great help. Also i was told there is a reset button but i dont see one.
Jun 28, 2009 at 9:22 AM
  • 75,988 POSTS
What you need to do here is get the computer scanned for OBD2 code/s to find out what's causing the light to come on. Oil light on-check the oil pressure with a mechanical gauge if normal replace the oil pressure switch abnormal could mean oil pump and engine bearings Resetting oil light see below
https://images.2carpros.com/forum/automotive_pictures/12900_oil_light_reset_1.jpg
Jun 28, 2009 at 9:33 AM
