1996 Chevy Camaro Acceleration Problem
21 MILES • 6 CYL • 2WD • AUTOMATIC
THEFLYPSYDE
My 96 Camaro has been having acceleration problems lately, everytime I try to accelerate my car kind of spudders and hesitates before it gets into gear, and other times when I try to accelerate it will just continuously hesitate and wont accelerate like a normal Camaro would.
Apr 7, 2010 at 7:00 PM
  • 75,988 POSTS
Tranny could be slipping if not do below
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Apr 7, 2010 at 7:28 PM
