1995 Chevy Camaro Wheel Stud Replacement
1995 CHEVROLET CAMARO
75,000 MILES • 6 CYL • 2WD • AUTOMATIC
MOTOSERVDOG
I have to replace 1 wheel stud from my rear wheel. What is the procedure to do this? I have drum brakes so does the axle have to be pulled from the pumpkin or is there some sort of access hole from the rear of the drum so I can just puch out the wheel stud? Thanks for your help.
May 22, 2008 at 7:51 AM
MERLIN2021
  • 17,250 POSTS
Remove the drum, use a ball peen hammer and pound it out, I use 2 hammers, leave one on the broken stud, and hit it with the othe, now spin the axle tyo get the new one in, use an impact and some large washers, and pull it into the flange...
May 22, 2008 at 8:20 AM
