1995 Chevy Camaro no reverse
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
STEVE70
i have a 1995 chevy camaro 3.4 6cyl with automatic trans. the trans shifts fine but reverse does not work . is there a sensor or a reverse gear that can be replaced
Aug 26, 2009 at 3:54 AM
2CARPRO JACK
  • 11,533 POSTS
Unfortunatly, if you have lost reverse, the trans will need to be taken apart to see what broke.I have seen them lose 1st, reverse, all of the gears seperatly and not make noise and still operate to some degree.Have a trans shop look at it and give you an estimate
Aug 26, 2009 at 8:22 AM
