1995 Chevy Camaro hood
DRICH88
1995 Chevy Camaro 6 cyl Two Wheel Drive Automatic
i have a 1995 camaro...the 1998-2002 camaro is basically the same car with a different hood, headlights and a few other minors...will the 1998 hood and front bumber fit my 95?
Feb 21, 2009 at 3:09 PM
TEAG
  • 158 POSTS
Yes you can use them but you need to have the mounting brackets for the front end from the 98. The 95 dont use the same mounts as the 98. Its not very hard. Im not a body work girl and Ive done it before with no problem besides getting the hood perfectly lined up. Thats the only pain in the rear part of the job. Good luck. Hope that helps ya out.
Feb 22, 2009 at 7:47 PM
