1995 Chevy Camaro freeze plug
197,000 MILES • 6 CYL • 2WD • AUTOMATIC
TAYLORSVILLE
The freeze plug on the front of the block has rusted through. How do I get it out?
Mar 18, 2008 at 3:29 AM
THE FACTORY MAN
  • 50 POSTS
Use a hammer and a punch with a large enough tip that it doesn't punch through the core plug. Tap the core plug near the edge in an area that hopefully isn't rusted and you will drive the plug into the cooling passage. You should then be able to grab the plug with vise grips and pull the plug out of the block.
Mar 20, 2008 at 6:23 AM
