My camaro started out running hot. I replaced the thermostat,and when I was filling it up with anti freeze,I noticed my freeze plug was leaking. I have yet to replace the plug, however, the car seems to be running very erratic. It will idle fine,but when I put it in gear, it starts to choke down. I can put the gas pedal to the floor, but it will not rev up. I have recently replaced all spark plugs and plug wires and fuel pump and filter. It should be noted that I had to remove the catylitic converter a few months ago.
Any Ideas????
Any Ideas????
Feb 29, 2008 at 1:20 AM
