1995 Chevy Camaro Clutch hydrolic system??
165,000 MILES • 6 CYL • 2WD • MANUAL
ZZTURBO
I have a 95camero rs 3.4L V6 and everything runs and drives great The clutch seems to have been replaced because it is super strong
...BUT!!! when i first go to crank it up i push in the clutch and start it then have to double pump the clutch to go into gear ...
once i start to drive it goes through the gears easy . BUT when i am at a red light with the clutch engaged in nuetral i have to pump it once more to get it back into gear, or its hard to register the gear...
Whats the Problem??
Dec 10, 2009 at 4:27 PM
  • 75,988 POSTS
Try bleeding the system that don't work check the clutch master cylinder
Dec 10, 2009 at 9:05 PM
ZZTURBO
the clutch cant be manually blead......its a self bleeding system...
Dec 11, 2009 at 5:32 AM
