1995 Chevy Camaro Clicking
113,000 MILES • V8 • 2WD • AUTOMATIC
MI-Z28
First time user here... I'll try to makes this short and sweet. When I turn the wheel all the way to the right and let the car edge forward I get this "Click/Popping" noise. You can feel it popping, but as soon as the wheel is straightened out it goes away.
It doesn't do it with simple right hand turns, it has to be a hard turn and only to the right. Any ideas?
Mar 7, 2008 at 4:34 AM
DAN P
  • 9 POSTS
Does the car have the option G 80 [limited slip diff] this a common problem on camaro and impala ss, the clutch plates bind, you can try a diff flush & add gm limited slip additive, this normaly works after you makesome tight turns ,but if it does not work, you may need a new unit, let us know if this works.
Mar 10, 2008 at 3:01 PM
