1995 Chevy Camaro Body Control Module???
TSHEP
Electrical problem
1995 Chevy Camaro 6 cyl Two Wheel Drive Automatic 152K miles
I have been having problems with my Camaro not starting. I have had my radiator checked, replaced my ignition switch and I have a brand new battery in it.
I had it towed to a Chevy dealer, and they told me that I need to have my ignition switch replaced. I had that replaced drove it home and 3 days laters it would not start.
I called them back and now they are telling me that it may be the Body Control Module. Is there a way I can determine if that is the problem? I just tried starting it and it will not start. I now my battery is fine it has a full charge.
I am trying to sell the vehicle, as I have been laid off since April. Need the money to pay bills.
What is my next step? Can I do anything myself to determine this is what it is, and can I replace this, if I can afford the part? Is this something I may be able to buy from a junk yard, just a thought???
Aug 19, 2009 at 3:54 AM
JDL
  • 16,098 POSTS
Hello, are you saying cranks good but won't start or won't even crank? If won't crank, do you think the theft system might be causing a problem? Have you tried a different key? Any codes?
Aug 19, 2009 at 4:18 AM
