1995 Chevy Camaro A/C Clutch
1995 CHEVROLET CAMARO
89,000 MILES • 6 CYL • FWD • AUTOMATIC
CAMER1226
My clutch on my air compressor makes a horrible rattle when driving the car. I would like to just replace the clutch itself, or is it better to replace the whole compressor which is more expensive.
Thank you
Feb 23, 2010 at 9:23 AM
HMAC300
  • 48,601 POSTS
if it makes noise while you have the a/c on then' it's the compressor and will need replacing along with the clutch. If it's not you should be able to replace the clutch, but might come as an assembly.
Feb 25, 2010 at 12:35 PM
