1995 Chevy Camaro 95 Camaro has heat fluctuations from driv
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
CANDYAPPLE95CAMARO
  • 6 POSTS
My 95 3.4L Camaro's heating rises close to overheating while in park, but when I drive it for about a minute or a little less it will cool back down to the normal operating temp.
Im really confused as to what could be the problem but it would make sense if there was a cooling problem.
I have checked the coolant level and it is fine and the oil is fine aswell
Thanks in advanced for any help you might have,
Ryan
May 27, 2009 at 11:44 AM
  • 110,248 POSTS
Ryan, does the car have a fan clutch attached to the water pump or electric cooling fans? IF it overheats when sitting still, which ever one you have isn't working properly.
Jul 3, 2009 at 12:47 PM
