Air Conditioning problem
1995 Chevy Camaro V8 Two Wheel Drive Manual
why is my a/c blowing only top and bottom, its not blowing in the middle I hope you know what I mean, can u please help me with this
Sunday, June 14th, 2009 AT 9:28 PM
DOCFIXIT
MECHANIC
Hi
Fault in vacuum operated accuator. Maybe loss of vacuum from engine, Master select switch or a failed accuator. Do you hear any hissing behind control panel? Look under dash on drivers side see three can looking things with vacuum line attached? Those are the accuators.
Hope this helps
Thanks for donate
