1994 Chevy Camaro White smoke
139,400 MILES • 6 CYL • 2WD • AUTOMATIC
JEFF T
Hose came off of pcpv so I replaced it. Then the car started to blow white smoke out the tail pipe. and the temp gauge went above the high side. I shut the car off, it smells kinda of sweet. So what do I do now?
Nov 2, 2008 at 12:11 AM
MASTERTECHTIM
  • 4,750 POSTS
sounds like you are getting coolant into the combustion chamber. most likely cause is a faulty iontake manifold gasket or a bad head gasket. its overheating because of loss of coolant being burned in the engine
Nov 2, 2008 at 12:14 AM
