what is the gasket behind the water pump gasket its is spraying coolant out when the pressure builds when running
Feb 25, 2010 at 7:16 AM
JDL
✓Experienced Mechanic
Hi, intake gasket--head gasket, hard to be sure without seeing the leak?
Feb 25, 2010 at 7:47 AM
BENNYBONES1
MEMBER
well it looks like from were u bolt the water pump that there is another gasket other then the 1 that between the part with the pully and where it is bolted its behind that
