1994 Chevy Camaro Unusual Vibration when accelerating
140,000 MILES • 6 CYL • 2WD • AUTOMATIC
JBEASLEY
I've been driving this car since 1994. I haven't made any modifications to this car and aside from replacing the alternator and EGR Valve, I haven't had any major probelms with the engine.
I don't know much about engines but recently my car has been vibrating more than usual when I accelerate or at a stop light. The vibration will subside if I lay off the gas or put in neutral respectively. What in your opinion could be the cause of this?
Apr 23, 2009 at 8:05 AM
TEAG
  • 158 POSTS
Check your plugs, wires ect... Worn plugs and or wires can cause vibration due to the engine missing. See what happens after a tune up and repost here if that dont fix it. Also check your fuel filter. Good luck :)
Apr 25, 2009 at 9:49 AM
