Hi there,
For the idle problem do a comp test and a full tune run a scan to check for set fault codes, for the oil pressure problem, first have the pressure tested with a master gauge as this will give a true indication as to engine oil pressure, if OK, replace the sender unit. Start here.
Mark (mhpautos)
SPONSORED LINKS
Friday, October 3rd, 2008 AT 1:52 AM
