1994 Chevy Camaro Quickly over heating in idle
CAMAROTUNE
  • 1994 CHEVROLET CAMARO
  • V8
  • 171,382 MILES
The car overheated on the freeway out of no where. When I had opened the hood there was coolant all over the driver side. Ever since then the car will overheat at the drop of a dime. Some suggested a bad freeze plug, but would that cause it to over heat at just idle? Any ideas?
Thursday, March 5th, 2009 AT 9:41 AM
DOCFIXIT
  • 18,828 POSTS
Check cooling fan operation and thermostat maybe stuck shut. If fans work and top hose stays cool then replace thermo.
Thursday, March 5th, 2009 AT 10:19 AM
CAMAROTUNE
Cooling fans work and I had recently replaced the thermostat
Thursday, March 5th, 2009 AT 12:49 PM
DOCFIXIT
  • 18,828 POSTS
Assume no coolant leaking out of engine. If yes have coolant checked for presence of CO. This would tell if a headgasket has failed.
Thursday, March 5th, 2009 AT 2:35 PM
