1994 Chevy Camaro power window
180,000 MILES • 6 CYL • 2WD • MANUAL
COREY1968
my window is stuck about half way down i dont have money to buy a new motor right now but i need to get window up befor more rain comes is there a way to move it by hand , i have the door panel off but i cant see much of the mechanism , what can i do
May 31, 2010 at 5:34 AM
BLUELIGHTNIN6
  • 16,542 POSTS
not really anyway to do it, if you think motor is bad try pecking hard on the window motor with a rubber mallet. it may get it working long enough to roll it up. otherwise you will have to break apart that window motor to allow the window to be forced up, but even then you will have to brace it up with something or the window will just fall back down since the motor was disassembled..
May 31, 2010 at 12:49 PM
