1994 Chevy Camaro oil pressure sensor and fuel gauge
TWEETERLEE
Engine Mechanical problem
1994 Chevy Camaro 6 cyl Two Wheel Drive Automatic
both my oil pressure sensor and fuel gauge are stuck .
the oil pressure reads way above 80 and the fuel gauge is stuck way above full at all times what is the problem and how can i fix that ?
Oct 2, 2010 at 12:37 PM
HMAC300
  • 48,601 POSTS
the guages are like that caue the wire is gorunded someplace. if you ahv erecently installed a switch or some type of thing where you drilled and screwed it in then chec k to see if you went through a harness and replace it. othewise you 'll have to see if the wires are grounded someplace..
Oct 22, 2010 at 12:31 PM
