1994 Chevy Camaro low oil pressure when warmed up missfire
BRYAN D
  • 1994 CHEVROLET CAMARO
  • V8
  • 234,000 MILES
My car has around 25psi of oil press, when its cold, but looses oil pressure to about 8psi when its around warm, it looses it threw out the temp increase, also starts misfireing when this happens, ive tried oil and lucas oil stableizer but no help, it is pumping water so it cant be running hot, what do u think it could be?
Thursday, February 25th, 2010 AT 8:21 AM
HMAC300
  • 48,601 POSTS
As you have high mileage on it it may be just main bearing wear. But it could also be a bad oil filter as well. But try using 10w30 or 40 as it's not known what weigh toil you are using. If you are already using that weight oil, then it may be time for either a rebuild or new main bearings at least.
Thursday, February 25th, 2010 AT 8:26 PM
