1994 Chevy Camaro idle irregullar (800-2000 when hot)
46,000 MILES • V8 • 2WD • AUTOMATIC
KHAN414
The car runs fine until the engine gets hot. Once hot, and you stop at a light it begins to idle irregular.
It jumps up from 800-2000. Once the car cools of agin its fine. I replaced the IAC and there is no engine code. Do you have any idea what could be the problem?
Oct 10, 2008 at 12:32 AM
  • 75,988 POSTS
Test the throttle position sensor/MAF/MAP sensors
Oct 10, 2008 at 1:49 AM
