1994 Chevy Camaro horrible noise
SNIBUL8OR
Noises problem
1994 Chevy Camaro 6 cyl Two Wheel Drive Manual 200k miles
my 94 camaro is making a grinding noise in the rear passenger side when i hit a bump. when i hit a bump the noise doesnt stop until i slow down or pull over. ive replaced the shoes hardware and drums and no difference
Feb 20, 2009 at 10:57 AM
DON OLIVER
  • 101 POSTS
you should be able to see the tire or wheel if it's rubbing on something. if the shock collapses and the body is rubbing, again, it'll show. if nothing is visible, check the end play in the axle and determine if you have a worn wheelbearing. good luck. sometimes the noise "transfers" to a different area. wouldn't hurt to check the front also. is the exhaust hitting the driveline? should be a visible sign if its an external problem
Feb 20, 2009 at 11:12 AM
