1994 Chevy Camaro Help
203,000 MILES • 6 CYL • 2WD • AUTOMATIC
ESR_HELLRAIZOR
i just bought this 94 camaro last night it's got 203000 miles on it it has been setting for about 3 months i was driving it home and it started to stutter the tak was jumping and lost power than quit i pulled over.. i stated it back up it ran for about 40 miles did the same thang. Could it be fuel gone bad in that short of time or mybe the filter.. i check oil it is in good shape not over heating that i could tell looking at the gauges oil psi was about 70 psi running at 70 on high way 14 voltz and it was on 1/4 tank when i got the car i put 20 in it that put it on full please help ty
Mar 18, 2009 at 2:36 PM
MASTERTECHTIM
  • 4,750 POSTS
most likely gas is not the problem. try unplugging the egr valve vacuum line and plug it and see if problem goes away. it sounds like it might be hanging up
Mar 18, 2009 at 10:52 PM
ESR_HELLRAIZOR
[quote:6a99ebc556="mastertechtim"]most likely gas is not the problem. try unplugging the egr valve vacuum line and plug it and see if problem goes away. it sounds like it might be hanging up[/quote:6a99ebc556] (Egr is electric no vacuum put I did unplug it and it did not help.. someone told me to replace the fuel pump relay i did that did not help. i was wondering something if the car dies and i try to start it back and it backfires though the throttle body could it mean it might be overheating just a thought I'm going to replace the water pump in the morning i thank is leaking out the weep hole and after this I'm going to be lost) I need to buy a code reader. and trying to use a paperclip does not work i tried
Mar 21, 2009 at 11:45 AM
MASTERTECHTIM
  • 4,750 POSTS
a code reader would help at this point to give us a direction to go
Mar 23, 2009 at 1:07 AM
