Engine Performance problem
1994 Chevy Camaro 6 cyl Two Wheel Drive Automatic
Hi i have purchased a 94 camaro..it has a 3.4 Litre v6 and i would like to swap it and put in a small block 350 from a 80 camaro..My question is how much work is it going to take and what components am i going to have to change in order to make the conversion?..I have heard several things such as changing wiring harness,having the get different motor mounts etc..i just figured i would ask you guys and see what your take on the subject is..thanks alot
May 3, 2008 at 8:29 PM
