1994 Chevy Camaro ENGINE SURGES
176,000 MILES • V8 • 2WD • MANUAL
SANDY50
AFTER CAR GETS TO OPEATING TEMP ENGINE WILL SURGE UP AND DOWN HAS NO CHEKC ENGINE LIGHT AND NO CODES I HAD IN A CHEVY GARAGE THEY REPLACED TP AND IAC MOTOR BUT CAR STILL ACTING UP
Aug 16, 2009 at 2:04 AM
  • 110,248 POSTS
Did they check the catylatic converter?
Sep 3, 2009 at 1:49 AM
SANDY50
THE CAR CAT CONVERTORS WERE REPLACED ABOUT 4 YEARS AGO ONLY TIME THIS CAR WILL SURGE IS WHEN WEATHER IS HUMID AND HOT AND WHEN YOU HAVE TO SET AT A STOP FOR A WHILE IN TRAFFIC
Sep 3, 2009 at 10:12 AM
  • 110,248 POSTS
Has the fuel pressure been tested when this happens? Also, did you have the ignition module tested? I wonder if it is breaking down in the heat.
Sep 3, 2009 at 1:46 PM
