1994 Chevy Camaro Engine Coolant
223,000 MILES • 6 CYL • 2WD • AUTOMATIC
CLARINETFLUTE
My engine is eating coolant. There are no obvious leaks. The coolant is leaking into the engine. There is no water in the oil. I've already had a garage pressure test the cooling system and they found nothing. Every time I make a trip (25 miles) I am out of coolant again. What is going on?
Jul 31, 2008 at 6:54 AM
  • 75,988 POSTS
My engine is eating coolant. There are no obvious leaks. If its not leaking then its being burned-up in the combustion chamber-could mean blown headgasket-cracked head or block-or an intake manifold leak-Is the engine overheating?
Jul 31, 2008 at 7:11 AM
CLARINETFLUTE
It's getting up to 250 degrees but not quite overheating. The coolant is disappearing, though, and I am having to add coolant every day now. I should add that it only goes up in temperature when I am in stop and go traffic or stopping with the engine idling.
Jul 31, 2008 at 12:39 PM
  • 75,988 POSTS
Bleed the cooling sysytem and see what happens-
Aug 1, 2008 at 7:30 AM
CLARINETFLUTE
I took the car to my trusted mechanic and he solved the big mystery. My fan relay motor was not working properly. So when I was in stop and go traffic and it wasn't running, the car would get hot and the coolant was boiling out of the recovery tank. I am so relieved I don't have to buy a new car right now. I appreciate your input.
Aug 1, 2008 at 8:12 AM
