1994 Chevy Camaro EGR Valve
1994CAMARO
Engine Performance problem
1994 Chevy Camaro 6 cyl Two Wheel Drive Automatic 197xxx miles
What would happen if I removed the EGR Valve and plugged the openings? I know it wouldn't pass California emissions tests, but I don't live in California anyway. The car seems to run fine, but has no low end power, you couldn't rotate the tires on gravel. I've replaced o2 sensors, plugs, wires, and map sensor. I also replaced the cat, which was plugged. Any other suggestions?
May 11, 2008 at 1:45 AM
BLACKOP555
  • 10,386 POSTS
change fuel filter, check the fuel pressure.
Change air filter
if you plug up the EGR ports the engine should run just find as long as the openings are plugged.
May 11, 2008 at 3:44 AM
BZBUAY
Bkackop555, will their be any difference in the performance or gas millage of the engine cause I am having the very same issues with my 94 Camaro?
Sep 5, 2012 at 1:48 PM
