1994 Chevy Camaro e-brake
133,000 MILES • 6 CYL • 2WD • AUTOMATIC
PIMPINPONCE
Can anyone help? how do you tighten the cable on your ebrake for 94 camaro?
Jun 29, 2008 at 1:22 PM
MERLIN2021
  • 17,250 POSTS
First thing to do is make sure the rear brakes are adjusted for a very slight drag, then back off a click.
hevrolet states adjustment is not normally needed, by adjusting rear brakes parking brake should be OK. But if you must, on drum brakes the adjusting screw is under the lever, use a deep socket to turn it. Disc brakes are different.
Jun 29, 2008 at 1:37 PM
PIMPINPONCE
Does your e-brake use your back brakes? Like if you haven't changed the rear brakes would it affect the e-brake?
Jun 29, 2008 at 1:56 PM
MERLIN2021
  • 17,250 POSTS
Jun 29, 2008 at 2:31 PM
PIMPINPONCE
thank you very much. this helped me very much, I was able to identify my problem and fix it. great feedback, very quick. i tryed posting feedback but it would not allow me to.
Jun 29, 2008 at 3:12 PM
MERLIN2021
  • 17,250 POSTS
I think you must donate to give feedback!
Jun 30, 2008 at 12:29 AM
