1994 Chevy Camaro car performance
127,000 MILES • 6 CYL • 2WD • AUTOMATIC
GMOLLOY
Sometimes when I start my car it idles horrible and and sometimes it will die. After I let it idle for 10 minutes its gets a little better but when I go to drive it and step on the gas pedal the car stutters. Sometimes when I hit the gas the car will speed up and then slow down even thou im pressing the pedal at the same rate. Do I need a fuel pump or is there anything else I should check.
Jan 27, 2009 at 9:05 AM
RHALL77
  • 3,361 POSTS
do you have a check engine light on? you may wanna check and see if the fuel pressure regulator is leaking. check for vaccum lines that are disconnected
Jan 27, 2009 at 10:15 AM
