1993 Chevy Camaro started
161,000 MILES • V8 • 2WD • MANUAL
SALLYDID
starter solonid - clicks sometimes- sometimes it starts put new starter in still does same thing checked voltage at starter - good
Mar 2, 2010 at 1:48 AM
JDL
  • 16,098 POSTS
hi, I'd have to make sure the battery has a full charge and the battery connections are good. When the problem is ongoing, I'd have to check the voltage readings, solenoid S terminal-- solenoid bat terminal-- I'd also check the voltage reading at the starter field terminal. Compare those readings, with the reading across the battery terminals, key in the crank position. See if there is any voltage drop, anywhere?
Mar 2, 2010 at 2:02 AM
