1993 Chevy Camaro no spark from coil
MMCAMARO93
Electrical problem
1993 Chevy Camaro V8 Two Wheel Drive Automatic
why am I not getting a spark from to the opti distributor?
Nov 24, 2009 at 10:25 PM
ERNEST CLARK
  • 1,730 POSTS
The Opti-Spark distributors are notorious for failure.
The main design flaw was they are susceptible to moisture. The moister causes arcing which causes carbon tracks inside of the housing.
If you can remove it, clean it out and replace it.
Also, check your ignition control module and the wiring and connectors.
Jan 8, 2010 at 1:27 PM
