1993 Chevy Camaro Injectors
JHC
Engine Performance problem
1993 Chevy Camaro V8 Two Wheel Drive Manual
Only one bank of injectors are working. Do you have a suggestion of what might be causing the problem? Injesctors have all been removed clened and put back in but the right side is not pumping fuel.
Apr 1, 2009 at 8:25 AM
  • 75,988 POSTS
Check injectors fuses no.9/10 7.5amp if okay at the one side that's not pulsing check for power at the pink wire on the injector harness connector if power is present the computer ground driver for that side is defective
Apr 1, 2009 at 10:06 AM
