1993 Chevy Camaro engine fuses... please help
187,000 MILES • 6 CYL • 2WD • MANUAL
BEACKER
one of the fuses that goes under the hood, is a injector fuse , every time i turn on the key, it burns up, and ive notticed that that problem makes my car to not have any power at all... do u know what can i do to fix this problem?
Mar 12, 2009 at 3:55 AM
MIKE H R
  • 3,094 POSTS
Check the wiring going to each injector. see if one is grounding out or is crossfiring. Make sure you check all the wires. I had a car one day that the injectors were replaced and I found that the guy did not unsnap the wiring harness to that injector but just clipped the wire and when he put it back together he just twisted the wire together with the he cut. after time this loosened and shorted out.
Mar 16, 2009 at 3:46 AM
